Highlighted
Blacklist cli not working
MM 8.4.0.2
Found this post from 2017 regarding the blacklist feature:
https://community.arubanetworks.com/t5/Wireless-Access/Blacklist-by-MAC-address/m-p/165752#M35249
Also checked the CLI reference guide:
https://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-a00065463en_us-1.pdf
I'm under the /mm context. When I type
show ap client status 84:25:3f:Od:98:ba
it says:
(host) [mm] #show ap client status 84:25:3f:Od:98:ba
Error : Invalid MAC address. Expected format XX:XX:XX:XX:XX:XX
also:
(host) [mm] #stm add-blacklist-client 84:25:3f:Od:98:ba
Invalid MAC address:84:25:3f:Od:98:ba
I don't see how that can be an invalid MAC address. I looked it up online and it comes back as a valid MAC.
Accepted Solutions
Highlighted
MVP
Re: Blacklist cli not working
your MAC address is:
84:25:3f:Od:98:ba
where you have typed "Oh-d" rather than "zero-d"
Just a typo methinks.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
View solution in original post
All Replies
Highlighted
EDIT
Did you try executing those commands on the MD, instead of the MM?
That should work.  I am not sure why the mac address is not working.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Same result :/ :
(host) [md] #show ap client status 84:25:3f:Od:98:ba
Highlighted
Got it.  I get the same error in 8.5.
Let me check.
Highlighted
MVP
84:25:3f:Od:98:ba
--Matthew
