CLI Output with AP345 in dual-5GHz mode
Hey Airheads,
right now I am refactoring a script which requests Data from the API and pushes that data into an InfluxDB. Because I want the script to support the AP340-Series, I need the CLI or API output of two commands from an ArubaOS 8.3.0.x system, where the AP340 is running in dual-5GHz mode. We don't have AP340 and thats why I ask here. The Commands are:
show ap active
show ap radio-summary
Thanks for you Help,
Hendrik
WiFi Enthusiast | ACMP
Re: CLI Output with AP345 in dual-5GHz mode
Screenshot 2018-09-08 at 07.42.30.pngI don't have the radio-summary output at the moment.  The W indicates dual 5ghz.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
So the radio-summary is not much different:
CAP-03-4thf-01	Road-Scholar	345	172.30.162.172	5	AP:VHT:44+	17.0/17.7
CAP-03-4thf-01	Road-Scholar	345	172.30.162.172	5	AP:VHT:140+	16.0/17.2
It just shows the AP name twice
Hi cjoseph
    I would like to ask, how to open dual 5G for IAP 345?
