Re: Cannot Configure VLAN on Aruba 620. Please help
I can see that you are doing 802.1x auth - right?
can you provide,
show ap essid ( as you mentioned the ssid is not broadcasting)
show profile-errors
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
Contributor I
seems that trunking is not working. What I did is, I change the port 6 as accessport  for VLAN is 20. It works. The SSID is working with my external DHCP. Now, I do the same on port 5 to use for VLAN 30 but it doesnt work. Any advise? thnks
  • Are u trunking - and using the same vlan tags?
  • can u printout your port config of all the trunk port u configured in your aruba please
Contributor I
This is the Port config on Port 0 where in my AP105 is connected.
This is the config on my Port6 where in my VLAN 20 is connected. This is working.
This is the config on my Port6 where in my VLAN 30 is connected. This is not working. SSID is broadcast but no IP address from my DHCP server.
Contributor I
sorry the last image should be this one.
OK
OK
lets do here some order.
You dont need to trunk the port that your AP-105 is sitting on..it's only need to be able to get an IP and to establish GRE tunnel in front of the controller.
(all the need vlan's - you will choose to transmit on air-via ssid will arrive to the AP via the GRE tunnel from one vlan...)
Next...
From your screenshots.i can understand that you got two diffrent other port - one for vlan20 and one for vlan30 both of them configured as access ports.
can u confirm that on vlan30 - u getting resposne from the controller on (when testing ping from other equitment to the ip of the controller on vlan 30 192.168.10.99)
configure another port as access to vlan30 and connect your laptop to it...check if u reciving ip address from it - if not your vlan30 isnt configured right (sub or DHCP)
 update me if when 1 port with vlan30 is connected to your backbone (vlan30)  and one to your laptop (both access) - if you gettning an ip.
me
Contributor I
I dont want the trunking anymore. Its make more complicated. I will be make it simple. 1 SSID and 1 Vlan 1Aruba port.
Contributor I
from my VLAN 20, I get response from my DHCP server
from my VLAN 30, I don't get response from my DHCP server.
I tried taking out the cable and connect to my laptop(straight from my switch), I can get IP Add, for both
VLAN 20 and VLAN 30
so - test with access role / AAA profile for both ssids.. check that u allowing users getting an IP (DHCP services) on the first role.
