Highlighted
Re: Cannot access web-management or captive portal
IE:
"This page cannot be displayed"
CHROME:
"This site cannot be reached"
ERR_CONNECTION_REFUSED
Highlighted
What is the URL?  Does it redirect to https://<ip address>:4343/URL?  What is the URL without the ip address that it fails on?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
i've tried with both:
and
Both give same error.
URL used to work with https://<ip address>
(i had it bookmarked on management workstation)
If i understood your question...
Highlighted
Hello
Getting same issue as described. Restarts do not fix.
(hostname) # show web-server stat
Error in featching statistics, Web Server is not responding
Did OP come up with a solution?
Highlighted
Controller firmware update solved the problem.
View solution in original post
