Highlighted
Frequent Contributor I
Re: Captive Portal Not using my Known CA Cert
Sorry - yeah, I know it doesn't need to be the hostname since it just pulls the name from the cert for the redirect.
Back to the original question though - if I do a CSR off box and put the cert on both devices, will that solve the problem of the cert not being used for captive portal?
Highlighted
Moderator
No. You can't pull the private key off a controller. You need to generate the cert on another box that allows export.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Thanks.
I'm still curious as to the answer to my original question.  I've put the cert on the main/active controller and set it to be used for captive portal, but it is still not being used.  Is this because I don't have the same cert on the inactive controller?  Or could it be something else?
I'm getting the cert reissued now with a CSR that was generated from somewhere else so it can be applied to both controllers, but should that resolve the problem of the captive portal not using the known CA cert I installed?  Or is there another issue?  It seems like since the active node has the cert, it should work now even though I don't have the same cert on the other node yet.
