Highlighted
Case Opening Error
Hi All,
We had a problem with transferring licenses from one controller to another. So, we'd like to open a case from Aruba Support Page.
Unfortunately whenever I tried to open a case, I'm getting this error below.
Web Company; Company: data value too large (max length=80)
I believe that I need to change my Company name because it's too long. However, page doesn't allowed me to do that.
I'm kindly ask your help...
Thanks in advance.
Highlighted
MVP Guru
Re: Case Opening Error
Please call TAC, so they can fix the registration issue, and open the case.
Phone numbers are available here: https://www.arubanetworks.com/support-services/contact-support/
Highlighted
Sir with all respect, I don't think those number are valid at least for my country.
Highlighted
MVP Guru
You can dial a number in another country. The phone numbers that start with + can be reached internationally.
