Channel busy
Some users are facing slowness some time, and the ping to the gatway is going high.
i want to know what is attached means.
is it related to the slowness issue. if yes, is that means users are utilizing below APs signal by high traffic.
Thank you.
Re: Channel busy
I would lower the ARM max and min power for the 2.4ghz band to see if that decreases the channel utilization:  https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/ARM/Configuring_Radio_Settings.htm
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
