Contributor I
Clean up flash on MM
we see this in the log of an VMM:
<CRIT> |nanny| There is only 1523 MB left on the flash. At least 2000 MB of free flash space is recommended to keep the system stable.
Any idea besides the "tar clean ..." commands if there is no obvious file shown with "dir" that will eat up the space?
Christian
Re: Clean up flash on MM
Try "tar crash".  If there is no file, it is possible there is a hidden filename that only TAC can delete.  If there is a crash.tar file, copy it off and then delete it.  Submit the crash.tar file to TAC.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
That fixed it.
Christian
