Highlighted
Contributor I
Re: ClearPass and Controller Roles
Agreed - will keep working with TAC.  I checked and do not see misspell but good thought.  Here is the show command of one that works and one that does not
Highlighted
no.
In the output of show user ip <ip address of user>  there is a line:
Role: authenticated (how: ROLE_DERIVATION_DOT1X), ACL: 96/0
That basically says how a user got its role (how:).  That is what you should be looking at.  In the line above, it said it got its role from role derivation.  Your user should have a reason, as well.
You also have two different aaa profiles for the one that works and the one that doesn't work, but that does not mean anything.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Contributor I
Double checked and do not see this in the CLI show user <IP ADDRESS>
Role:authenticated (how: ROLE_DERIVATION_DOT1X)., ACL: 96/0
Highlighted
What version of ArubaOS is this?
Please PM me that entire output
Highlighted
For a shorter output, try "show user mac <mac address of user>"
Highlighted
Contributor I
