Occasional Contributor I
Client VS AP Radio PHY
Does anyone know if it is normal to have a Client on 20 MHz VHT, while the AP is on 40 MHz VHT?
I have a client on an isolated AP and SSID that is getting rediculous client retransmits like it can easily be well over 100% , it makes it so the network is basically useless. The SNR is 51 DB as the client is like 15 feet max from the AP and has direct line of sight.  Just trying to figure out why this has such a high retransmit rate.
Re: Client VS AP Radio PHY
What is the client? What type of encryption are you using on that SSID?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
It's a Roku device, and the SSID is using wpa-2 Personal.
Is it on the 2.4ghz or 5ghz band?
5Ghz  band.
I would use the commandline and is the "show AP association client-mac <clientac address>. It will provide more objective information than the GUI.
