Re: Client issue after changing from tunnel to bridge mode
Is the issue that clients are not getting DHCP?
What is the topology and how is this site connected to the site with the controller?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Occasional Contributor I
I was never able to get this to fully work in bridge mode and couldn't keep trying different things as it was causing lots of down time for my students.  Unfortunately I had to change it back to Tunnel but I really want to get Bridged mode working correctly.
jwoodworth90,
If it is important to you, please open a TAC case so they can look at it in detail to see why it would not be working in your case.
I Did and after about 4 days of not being able to figgure it out I had no chocie but to setup as tunneling so the students could actually use the newtwork.
jwoodworth, what is your issue?  Please open a separate thread about it.
If you are not getting anywhere with TAC, you can have the case escalated.
I am Having the same exact issue as the Original Post.  When things slow down a little bit here i might be able to try this again and work with TAC.
Super Contributor II
This is a remote office connected through our WAN ISP, on site we have a single cisco switch setup with one single VLAN terminating in the ISPs equipment. DHCP is given by the ISP.
On the other end of the WAN is the customer HQ with a Palo Alto firewall connected to a mgmt zone where the controller resides. All the necessary ports for AP->Controller communication is in place.
The controller is connected to client-VLANs including vlan 126 where the users are getting their IP-address right now with the split tunnel configuration.
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP ACDP | CWNP: CWNE #306
What was not working with bridge mode...dhcp?
For ~3 clients yes. Read the original post for a more detailed description of the issue.
Correct, Some would get DHCP and Some would not. DHCP Pools had plenty of
addresses available.
*Jeremy R. Woodworth*
*Network Supervisor*
*Mentor Public Schools*
