Highlighted
All-Decade MVP 2020
Re: Client issue after changing from tunnel to bridge mode
Jeremy: is your problematic clients always the same ones or does it differ? Did you double check that you have all your client VLANs tagged to the APs running bridge mode?
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP ACDP | CWNP: CWNE #306
Highlighted
@Christoffer wrote:
For ~3 clients yes. Read the original post for a more detailed description of the issue.
Were those the only 3 clients with the issue?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
All-Decade MVP 2020
Colin, to my knowledge yes. Out of about 20 clients in total.
Highlighted
@jwoodworth90 wrote:
Correct, Some would get DHCP and Some would not. DHCP Pools had plenty of
addresses available.
*Jeremy R. Woodworth*
*Network Supervisor*
*Mentor Public Schools*
jwoodworth90,
Please open a TAC case when you are ready to troubleshoot.  They would need to have your toplogy as well as what kind of DHCP server you are using, along with your logs.tar from your controller.
Highlighted
Occasional Contributor I
All VLANS were tagged and the clients were always different.
Highlighted
All-Decade MVP 2020
Ok Jeremy, your problem is something else than mine then. My problem always affects the same set of clients, hence I asume it to be some sort of client issue.
Highlighted
Christoffer,
You said the DHCP server is a router?  Is there any way to turn that off and deploy a different DHCP server that would have more diagnostic information about why ip addresses are not being received?
Highlighted
jwoodworth90,
Since you do not have that setup in place, you should open a case with support when you have your setup in place, since we cannot get any specific data from your setup about what could be happening.  The factors leading to your issue could be numerous or individual, but without your setup in place, we cannot uncover anything in this thread...  On a basic level it should work and it works in many environments.  Unraveling why yours does not work requires your logs as well as a diagram of your infrastructure when your setup is in place.
Highlighted
All-Decade MVP 2020
I believe the ISP has a windows machine for DHCP and they use IP-helpers from their CPE. Anything special I want to check I´d have to involve them for troubleshooting.
Highlighted
Christoffer,
Since it is the same 3 devices, have you tried putting those 3 devices at a different site with the bridged configuration to troubleshoot?  If it is only those three devices, those should be the focus.
You should build a test environment with the same configuration to understand what works consistently and try to make it as close to your existing environment as possible, so we can understand where this could break.  The ISP and their DHCP server is the key to understanding what is going wrong.  You might want to schedule a window with the ISP and Aruba TAC to do some end to end testing to understand where the dhcp packets could be dropping.  I don't want to just take the ISP's word that everything is being delivered reliably and DHCP is being sent back.  You said your packet capture indicates that dhcp is not returning, we need to know where it is being dropped with genuine end-to-end testing.  That is the only comprehensive solution to this...
