Highlighted
Contributor II
Re: Clients being dropped following ArubaOS upgrade to 6.3.1.2
Have you found a solution to this problem? If yes, can you share your solution? What changes and fine tunes did you do to the ARM and Radio settings to manage this problem?
Highlighted
Unfortunately, that isn't easy to answer here and most likely wouldn't help your own situation.  I say that because our problem was actually a number of different issues that involved the controller configuration as well as specific settings in our underlying wired network.  I worked with support for a lengthy period of time on this but it did yield improvements, so you may want to contact support as well if you've had long running problems.
