Highlighted
Frequent Contributor II
Re: Clients seem to randomly lose access
If you look at the ARM history you'll see that a lot of channel-switches are occuring (by ARM), those can be disruptive.
Questions:
- Are there muching AP's on the same channel active?
- What is the noise-floor the AP's are reporting?
If you have lots AP's on the same channel (at least for 5GHz), you could consider moving to 20MHz channels (instead of 40MHz as it seems to be know).
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
Highlighted
Where do I check the noise floor?
We have a dozen APs so yes they are all on 1, 6 or 11.   There isn't a lot of switching between channels but there is some.
Can you let me know where to go to change from 20 to 40hz?
Highlighted
@boe wrote:
The noise should be a column on the AP display in the GUI.
You can change from 40 to 20 by going to RF> Advanced and Change "Wide Channel Bands" to "None".  Did you change the "Min Transmit Power" on that page to 9?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Highlighted
In the RF Dashboard section I see
All access points - utilization, noise and errors with only 1 green bar at the bottom of each.
In RF advanced, ARM, I see
Band steering mode - prefer 5GHz
Airtime fairness - fair access
Client match - enabled
CM Calculating interval 3 sec
CM neighboring match 75%
CM threshold 5
SLB mode Channel,
min transmit 3
Max 21
Client Aware disabled
Scanning Enabled
Wide Channel bands and my choices are 5GHz, none, all, 2.4GHz
I have 80MHz support and my choices are disabled, enabled
RADIO
2.4GHz band
legacy only diabled
802.11d/802.11h disabled
beacon interval 100ms
Interference immunity level 2
Channel switch announcement 0
Background spectrum monitoring disabled
Custom Arm power range (unchecked)
5GHz band
legacy only disabled
Highlighted
Why is max transmit as high as 21?  That causes roaming issues an disconnects..
On the SSID portion of that SSID, do you have "Broadcast Filter ARP" enabled?
Highlighted
Someone recommended I set a max earlier to help with the disconnects.  I'm happy to try anything to stop the clients from having issues.
Currently ARP broadcast filtering is set for disabled - would you suggest enabling it?
Currently I have
Broadcast filtering disabled
DTIM interval 1 beacon
Multicast transmission optimization disabled
Dynamic multicast optimization disabled
DMO Channel utilization threshold 90%
Transmit Rates
2.4GHz min 12, max 54
5GHz min 12, max 54
Highlighted
They recommended a max of 15 or 18. Power is logarothmic, so the power at 18 is half that of 21. 15 is a quarter of that.
Highlighted
I tried setting it to 18 and the clients complained they had even more issues.
Highlighted
I would open a tac case in parallel, because it seems we are not getting the full picture.
Highlighted
Thanks - I've opened a case... Trying to get any info at all from the client e.g. computer name, when they drop, are they stationary or moving...
In the mean time would you suggest turning on arp filtering?
