Highlighted
Frequent Contributor I
Cluster Reference Could Not Be Released
Attempting to rebuild my cluster for CoA. I can't remove my second Cluster member..WHY. I'll be blowing it away I guess but I'd like to know for future the reasoning..
Highlighted
MVP Expert
Re: Cluster Reference Could Not Be Released
Was it first removed from the cluster config above it?
Jerrod Howard
Distinguished Technologist, TME
Highlighted
I can't delete it from the Cluster config in the group.
Error: Can not delete cluster profile as cluster group-membership with profile 'Cluster1' exists at node Managed Network > The-Beatles > Cluster-1 > 00:0c:29:c1:fc:36
So I attempt to remove the Cluster membership config from the MC itself...
Cluster reference could not be released.
Highlighted
Contributor I
Any solutions for this? I have the same issue.
Highlighted
Contributor I
For all who may have the same issue:
The reason is a change of the group names in the Managed Devices section. If you change the group name after assigning a mobility controller to that group where the mobility controller is part of a cluster, the cluster configuration of the controller cannot be changed anymore.
Changing the group name back will enable you to change the Mobility controller cluster configuration.
For this reason, I highly recommend to think about the group naming in advance.
Moreover it would be nice to have a mechanism implemented that prevents to change the group name.
Highlighted
This is not the case with my setup.  Are there any other possible solutions to this error.  1 cluster member I can remove, the other I cannot.
Highlighted
Contributor I
Hey,
Having the same problem here, running 8.4.0.0 in a lab. Can't find a solution (CLI or GUI).
It is not possible to delete the controller from the MM because it is in the cluster...
appreciate any thoughts.
Highlighted
I was able to resolve this be rebooting the MM controllers.  It was just a lab setup so no big deal.
Highlighted
Contributor I
Thanks! I will try!
Highlighted
Contributor I
That worked! although I had to boot both MMs at the same time. Previous attempts with one at a time did not solve the issue. Thanks again!
