Compatibility issue
I have set of Aruba 7210 controller with different models of access points like 200 and 300 series . On instant access points  i can see all the access points but when i connect these Access points to controller through switch im unable to see any AP on controller although i have enabled dhcp server on controller .
I am new to this Aruba world kindly suggest what should i do now ?
Help would be appreciated .
MVP Guru
Re: Compatibility issue
Have you converted the Instant APs to campus APs? They won't show on the controller otherwise..
Check this video out for details of how to convert the APs:
https://www.youtube.com/watch?v=Wfl6gYPuyVs
Cheers
James
Thank you very much !
after converting now access points are visible on controller.
Actually firstly it was not converting Ap to campus but it converted .now
Thank you again
hi sir, is it the same method if i have newly bought IAP 315 and need to join to my virtual controller? do i need to convert first my IAP 315 to campus AP and it will automatically detected by the controller? thank you.
MVP Guru
No. That's a different issue. I'm assuming you are just adding a new IAP 315 to an existing IAP virtual controller?
Just patch the new AP into the L2 network that the existing IAPs are on. It should just appear on the virtual controller IAP web console.
Be aware that you need to ensure that the existing IAPs are on a firmware version that the new IAP supports.
Cheers
James
