Contributor II
Re: Configure 7210 with failover
Thank you I found the client sync, however looks like it is recommended to use the VRRP design if I am doing Master redundancy i.e; two masters.
There are quite a few options.  A common deployment is with a master/backup master, but the access points connect to and are backed up by locals connected to those masters.  You would be able to do state sync between those.
AP fast failover was introduced back in ArubaOS 6.3 where access points would be capable of failing over to a second controller in 5 seconds or less and clients very soon after.  In practice, this means that the network would recover before most people would be able to make a phone call about it, even without state sync.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
