Highlighted
Connections issue and Logs
Hi everybody,
I saw this logs on the controller,
wms[6003]: <126065> <6003> <WARN> |wms| |ids| AP(90:4c:81:ad:27:e0@90:4c:81:c2:d2:7e): Valid Client Not Using Encryption: An AP detected an unencrypted frame between a valid client (00:10:20:cf:ef:27) and access point (BSSID 90:4c:81:9f:9d:52), with source 00:10:20:cf:ef:27 and receiver 33:33:ff:cf:ef:27. SNR value is 36.
this SSID is using mac address authentication(00:10:20..) with ClearPass,
when appeared this log all the devices with mac 00:10:20.. lost connection for a few seconds.
any know what means this log??
Highlighted
Re: Connections issue and Logs
A "Valid Client" is a client that has used encryption on your system.  If the system observes the mac address of the same client not using encryption an open or captive portal SSID on another system for example) it logs that message.  It is nothing to worry about.  You can remove that alert in the IDS settings.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Thanks for your answer Cjoseph!!,
Do you know, if after that a "Valid Client" Log, appears this log:
wms[6003]: <126035> <6003> <WARN> |wms| |ids| AP(90:4c:81:ae:40:a0@90:4c:81:c2:e4:0a): Disconnect Station Attack: An AP detected a disconnect attack of client 00:10:20:cf:ef:27 and access point (BSSID 38:17:c3:8e:22:52 and SSID devices on CHANNEL 64). SNR of client is 9. Additional Info: Avg-Deauth-Disassoc-PktRate(pps):0.9; Interval(sec):10.
it´s a desconnection?
thanks!
