Highlighted
Occasional Contributor I
Re: Connectivity between wired and wireless clients
Talked with Aruba support and got this issue resolved.
I did not need anything written in the Wired section.
The port was set to switchport access on the router so on the AP I didn't need to set up anything under client VLAN.
If I had the port set to trunk, I would have needed to set that.
I hope this helps anyone else that might have that issue.
