Highlighted
Re: Controller 650 wont pull DHCP IP on WAN
Curious if you found a resolution for this.  Had an upgrade yesterday where they swapped cable modem from a ebee to an Arris and wan interface on controller no longer can get an IP address.
Highlighted
evidently some Arris Cable modems have bad chipset and cause DHCP issues.  Once it was replaced dhcp on wan port works fine
