MVP Guru
Re: Controller doesn't seem to pass ip addresses from various vlans
That looks good , Now see if you can ping the IP address assigned to those VLANs from the controller ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
MASTER
(3600_Master) #ping 10.12.20.1
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 10.12.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.631/2.8256/5.594 ms
(3600_Master) #ping 10.12.21.1
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 10.12.21.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.515/16.1898/61.164 ms
(3600_Master) #ping 10.12.22.1
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 10.12.22.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.181/5.1252/12.016 ms
(3600_Master) #ping 10.12.23.1
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 10.12.23.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.271/7.735/15.699 ms
LOCAL
(Aruba7210-US) #ping 10.12.20.1
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.009/1.4772/1.83 ms
(Aruba7210-US) #ping 10.12.21.1
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.048/5.0836/20.198 ms
(Aruba7210-US) #ping 10.12.22.1
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.736/2.6836/7.683 ms
(Aruba7210-US) #ping 10.12.23.1
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.894/3.7322/6.036 ms
all seem to ping just fine.
MVP Guru
And also if you can get an IP connecting your laptop to one of the ports on the controller using one of the VLANs that are not working
Thank you
Victor Fabian
MVP Guru
When you get a chance please share your VAP config ?
Thank you
Victor Fabian
MVP Guru
Do you get an IP if you just assign one VLAN to the VAP ?
Thank you
Victor Fabian
wlan virtual-ap "FortOsage-Mobile-vap_prof"
aaa-profile "FortOsage-Mobile-aaa_prof"
ssid-profile "FortOsage-Mobile-ssid_prof"
vlan 720-722
band-steering
vlan 720-722
band-steering
yes my laptop directly connected was able to recieve an address of 10.12.21.4 /24
i did allow vlan 721 and 722 on the 0/1 port of my master controller.
yes.
its when i add more then one is when the problems start.
MVP Guru
I don't think you an issue but based on the way VLAN pooling algorithm works devices will be place in the same VLAN :
The hashing algorithm does not place users into the available pool of VLANs in a round-robin method. Ten clients that join a WLAN are not load balanced equally among the VLANs. Instead, the distribution is based on the output of the hash. One VLAN might have more users than the others. For example, consider 150 clients that join a WLAN with just two VLANs in the pool and with 80 addresses per VLAN available for clients. Based on the output of the hashing algorithm, 80 clients are placed in one VLAN and 70 in the other. When the 151st client joins, the output of the hash might place the client in the VLAN whose scope of 80 addresses has already exhausted. The result is that the client cannot obtain an IP. To avoid such a rare situation, the network administrator should design pools with sufficient number of user VLANs and DHCP scopes to accommodate the user density.
What exactly you are trying to accomplish ?
Thank you
Victor Fabian
can you provide us the output for
show ap association client-mac <client-mac>
show user | in <mac>
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
