Highlighted
Moderator
Re: Controller integration with OneLogin
Most devices do not support EAP-TTLS without a configuration profile or custom supplicant. What type of device are you testing with?
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Occasional Contributor I
Tim, that means protocol is defined on client? Cool, I'll check on Monday
Highlighted
Tim, I checked it today, everything is working perfect.
For Mac OS X I used Apple Configurator 2 to create profile for EAP-TTLS/PAP, then it can be easily applied to all laptops.
Not tried, but it should work out of the box with Linux, Android and modern versions of Windows (8+).
Thank you very much!
