Occasional Contributor I
Controller management access lockdown
I am new to Aruba and I would like to change 2 things on my new controller 9004 which I use mainly for vpn access.
1. Disable mgmt web access to the interface outside ( public) https://X.X.X.X:4343/login.html. I want only interface inside ( internal ) to be used for web mgmt, ones a user is securely connected via vpn from outside.
2, I want new via users to be able to reach the webside where via install files can be downloaded https://X.X.X.X:4343/via but as I mentioned before I do not want to get anyone access to web gui for mgmt.
Thank you for help :)
Re: Controller management access lockdown
you can check the AOS hardening guide from here.
https://support.arubanetworks.com/Documentation/tabid/77/EntryId/16036/DMXModule/512/Default.aspx
There is a section on "Locking Down Administrative Access"
Thank You for the answer :-)
