Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Re: Controller upgrade from 6.1.3.6 to 6.3.0.1
Your question is what changed? The answer is a great deal. Does it cause the problem you witnessed? That can only be answered by opening a support case to determine exactly what is happening.
Is the Mac failing on the radius server side due to a radius certificate change? Is there something incompatible that makes the Mac ask for credentials again? Opening a case is the best way to troubleshoot something specific like this.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Ok. I'll open a case with TAC tomorrow and see if we can pinpoint what is happening. That was going to be my next step but wanted to post something on AH in case others experienced similar issues and might have know of some items to check.
Thanks.
