Highlighted
Re: Custom Captive Portal - no login possible
We are having issue with our custom captive portal, I tried using the sample template (found here: https://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/10187/1/Custom%20Captive%20Portal%20Web%20Guest%20Access.pdf) the problem is clicking on the I ACCEPT doesn't do anything.  I'm assuming it's something to do with the form as well - except we don't require any login - just click on "I ACCEPT" button.   Any idea how I need to change the html for this to work?
THanks in advance for any help you can provide.
Highlighted
Frequent Contributor II
Hi!
Sorry for the delay, I was on vacation...
Because of the Info on page one of the PDF
Spoiler
Product and Software: This article applies to all Aruba controllers and ArubaOS version 2.5 and later.
I think the template is a bit older.
If you don't resolve your issue yet, I recomend to compare the code of the sample template and the original built in default html of your controller.
There should be a similar button, try to customize the template along the original code.
Good luck!
Best regards/Mit freundlichen Grüßen
Matthias
