Contributor I
Custom EIRP values per AP group?
Hello all,
On our network I have created and AP group based on a physical building or location. I would like to customize radio settings, such as EIRP values for ARM, on a per building/location basis. When doing this for one buidling AP group it changes it for the whole network. Is there a way to do this without having to laboriously configure each AP individually in the "AP Specific" tab?
Any advice would be much appreciated
Re: Custom EIRP values per AP group?
For ap-group, you would have to first save a copy of the radio profile, and then save a copy of the ARM profile under that. You can then apply the copied radio profile and the copied ARM profile under that to a different AP group.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
