Contributor I
Re: D- Flag issue
3501G mid span poe injector and 4948 switch
Re: D- Flag issue
Are there any messages on the switch to indicate power problems? If not, I would try to see if there is a duplicate address on the network for that lms-ip.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
Re: D- Flag issue
I will check from switch end. Any best way to find out whether ip is duplicated? Thanks in advance.
1 more query. lms-ip should be a physical ip or virtual ip..?
Re: D- Flag issue
You would have to disconnect the link on the controller and ping the lms-ip. The lms-ip can be virtual or physical.
Contributor I
Re: D- Flag issue
But sad part is.. we face this issue in multiple locations.. ip cannot be duplicated in all places right.. but 1 relevance is wherever we have 7010 with 6.4.2.9 we face this issue. We recently upgraded to this version. :(
Re: D- Flag issue
Im having the same error code. 2930 does not indicate duplicate IP address. Also the site is managed by APC, and it has a VC. No physical controller.
System info:
VC = RAP325 Version: 6.5.4.5
( This is an AWE Account, Certain information is not permitted to be posted on this site)
AP is connected to Aruba 2920 Version: WB.16.04.0008
This is the Port Config:
Running configuration:
interface 1/22
poe-allocate-by value
poe-value 33
dhcp-snooping trust
tagged vlan ** Omitted **
untagged vlan 802  <------------ VLAN for AP's
spanning-tree bpdu-protection
loop-protect
arp-protect trust
exit
We cannot upgrade FW to higher version. This version is the approved version for the account.
We checked for VC-Relection bug - was fixed by turning off all AP's minus 2, failed over to new VC, and power cycled the old VC.
This did not seems to resolve the issue either
Is there anything you can suggest or have me check?
Re: D- Flag issue
The original poster has a controller-based solution.  The infrastructure does not seem to match your issue.
Re: D- Flag issue
I suggest opening a new thread on this for visibility. Your issue is not the same as the original post in this topic, since you're using Instant APs without a controller, different AP model, different version, etc.
Charlie Clemmer
Aruba Customer Engineering
