Highlighted
Re: DMZ Controller Guest traffic in Aruba OS 8 recommendation deployment
Hello Charlie thanks for answering
Right now im tunneling the the Guest vlan to the Master controller in the central site, and i got another tunnel from  the central site to the DMZ
Now for the authentication, i should be authenticating them on the Local controllers(remote controllers) because im on the clearpass adding the local controllers as NADs, to make it work, if i dont add them, well it does not work.
Now is there any issue if i tunnel the GRE to the master controller instead of the DMZ directly?  i see that you said that it does not add any functionality but i was wondering if it bad somehow.
Project engineer
Highlighted
All good info, thanks for the clarification and verification.
Tunneling through the master controller is not bad. It adds an extra failure point, although you have mitigated that with a standby master. There could be extra complexity in the configuration and troubleshooting, but as it is working for you now, that is all okay.
Charlie Clemmer
Aruba Customer Engineering
Highlighted
Thank you for your patience Charlie!
thanks for your answers too
Project engineer
