Data rate and wired speed in APs
Hi guys,
Let's take AP 375 as an example which has a max aggregate data rate of 2 Gbps. What's the actual wired speed or the actual speed on its wired port? Can I assume it will be the throughput, which is around half of the data rate? So can I assume in optimal conditions the AP will have wireless data rate of 2 Gbps and a wired data rate or speed of 1 Gbps? If not, what will be the value I will take for sizing the wired network?
Julián
Re: Data rate and wired speed in APs
I don't think it requires that much thought.
1- Put each access point on a gigabit ethernet link.
2- For each 100 access points that a controller terminates, give that controller a gigabit ethernet uplink to the core of your network.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Yeah, that's correct. But I mean for sizing the access switches uplinks. For example, if I have an access switch with 10 AP-375, what uplinks toward the aggregation/core layer I have to plan for? 10G uplinks? 20G uplinks? And if I have 24 AP-375 on an access switch? Those are just examples.
After that, yes, for each 100 access points the controller needs a gigabit ethernet uplink to the core.
Julián
I don't see that you would plan any different than a regular wired network, since most networks carry wired and wireless traffic.
Well, the thing is my customer has an already deployed switched network, with access switches with 1G uplinks toward the aggregation layer. I am going to install many APs (he doesn't have wireless currently) and use new dedicated switches for these APs. Think like 24 PoE+ port switches with 24 AP-340, so I don't know the sizing of these switches uplinks toward the aggregation layer, and that's the reason of asking about the APs' speed in the wired side. The AP-340 datasheet says "aggregate peak data rate of 3.0 Gbps in dual-band mode", so I can think
24 x 3 Gbps = 72 Gbps of uplink --> it doesn't sounds good
OK, 3 Gbps is the maximum peak data rate, let's take the half
24 x 1.5 Gbps = 36 Gbps of uplink --> it still doesn't sounds good
Any tip?
Julián
Julián
What application(s) are you customers going to be supplying at 3gigs?  If the internet is not 1 gig, if the customer's email servers and file servers are only connected at one gigabit and wired users already share those resources, you should be fine.
That makes a lot of sense! Thank you very much!
Julián
Hi Colin,
Please one more doubt about this. As I said, my customer has all the switched network with 1G links, for access ports, between access and aggregation switches, and between aggregation and core switches. I have around 200 APs so I would need one 10G uplink or two 1G uplinks from the controller to the core, but the traffic will be limited to 1Gbps through the network. In this situation, does it makes sense to give the controller one gigabit ethernet uplink to the core for each 100 APs?
Julián
You will need to measure the customer's traffic pattern and the utilization on that link to make that determination.  I don't know your customer's network.
But as an example, does it make sense to have two 1G uplinks from the controller to the core if there is a bottleneck of 1G through the switched network? So the speed through the GRE tunnels from the APs to the controller won't pass 1Gbps due to this bottleneck.
Julián
