Regular Contributor I
Re: Database syc failed between Master and Master-Standby. VRRP working !!!
What information is required to create the  master redundancy and data synchronization ?
Can you please mentioned the steps to create the master redundancy ?
your cooperation in this regard will be highly admirable.
looking forward.
looking forward.
Dear joseph
for master redudancy we have configured th vrrp according to the steps mentioned in the link provided by you. But still the output is same. :(
The key is to execute this, first on the master:
config t
master-redundancy vrrp <vrrp id>
peer ip address <backup master>
master-ip <backup master>  ipsec <key>
Then execute on the backup master
config t
peer ip address <master>
master-ip <master>  ipsec <key>
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Please find the below snapshots
You should remove the master-redundancy configuration from the backup and re-apply it.  It is saying that the master ip address is the VRRP address and not the master's ip address.
Can you please explain.... On the backup controller what changes are required ?
Please open a TAC case about this.  I want to make sure you are not running into a bug.
You are requested to please fill my configuration.
Master controller vlan 20 ip 10.20.0.1
Backup controller vlan 20 ip 10.20.0.2
VRRP 20  ip address 10.20.0.3
Key abc@2015
config t
Then execute on the bakcup master
config t
