Re: Database syc failed between Master and Master-Standby. VRRP working !!!
On the backup master:
config t
master-redundancy
no master-vrrp
no peer-ip address
master-vrrp 20
peer-ip-address 10.20.0.1 ipsec abc@2015
If that does not work, please try using a key that does not have an @ sign.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Regular Contributor I
According to your guidance I matched all the steps with my current configuration. I also changed the key but the outcome is negative.
Moderator
hi
please run the following two commands on the backup controller and paste here:
show process monitor statistics
show processess | include db,mys
show log error | include dbsync
you may be hitting known bug 116628, the output from the above commands will allow me to confirm it
regards
-jeff
Please note your desired information in the attached file naming  ""Logs"".
Please open a support case so that you can get help.
Moderator
+1 to what Colin just mentioned, time for a support case - the logs attached do not show any match with the known issue, so something else is going on.
It looks like the keys in your VRRP 20 are mismatched:
Invalid advertisement received for VRID 20, Mismatched authentication type
