MVP Guru
Re: Device with static IP not communicating, showing 0.0.0.0
What about if you check the logs from the CLI ([slow log XX]. Are the
clients able to connect if you set a static IP? Do you have an Open SSID
you can get the client connected to as a test?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Most of the clients on this network are set statically.
This device is also set to a static address. It just shows up as 0.0.0.0 and will not communicate.
I had a temp network set up in my office and it connected and communicated just fine, but that was with an EnGenuis AP.
MVP Guru
Care to share a tech-support from the AP with the MAC of the device in question?
Sure what do I need to do?
Just wanted to check in and see if you had anything further to try?
Thank you for the help so far.
MVP Guru
Log in to the CLI using Putty or similar and run #show tech-support and post the output. I’d suggest removing any sensitive or customer data before doing so.
Cheers,
Craig
I'm really hoping this is what you are wanting lol.
I'm sure you don't need all of it but I didn't want to remove anything other than the personal company details.
Any luck looking through that dump file?
