Does Aruba connects directly ONLY to controller?
Hello everyone!
I'm interested in studying Aruba Wi-Fi AP, but i couldn't understand one thing.
Does APIN315 NEED to be plugged directly in Aruba 7000 Series Mobility Controllers or can it be used through third-party switch with PoE (i have Juniper 4300)?
Is there any option of controller on Virtual machine that i could use alongside with hardware, that i already have or do i need to buy a controller(for example, ARUBA 7005 mobility controller)?
Regards, 9Apps VidMate
Aruba
Re: Does Aruba connects directly ONLY to controller?
APIN0315 is the regulatory model number, not the AP model.
You may have a controller based AP-315 (which requires a controller), or an IAP-315-xx which operates without a controller (Aruba Instant).
Both share the same hardware and RMN.
An Ap-315 cannot be converted to IAP-315.
/Onno
