Highlighted
Dual ethernet port AP535 configuration best practices
Hello folks,
What would be the best practices for connecting AP with both ports in term of a switch config without leveraging LACP?
I observe a layer2 loop every single time AP is connected to the network with both ports. The loop goes away as soon as AP found MC.
Thank you
