I would say that migration of standalone to MM is the same regardless of AOS version. The CLI commands are more or less the same - migrating as-is. Migrating just a couple of boxes doesn't warrant migration-tool imo.
In short..
Deploy the Mobility Master, create your tree-structure and copy config on a CLI level. Do a license migration. Take Controller Two (the inactive one) out of the VRRP cluster, write erase and connect it to the MM. Do device-specific Config. Add some AP to this and verify that all is working.. Move all AP's to new MM-MD. Make sure you whitelist the AP's.. If your AP's are configured to use VRRP - just move VRRP-master to the MM-MD
Then repeat the process with Controller One.
This way you can prepare everything during daytime, and move AP in a short maintenance window. You will also have the option of fall-back if things go bad :)
