Frequent Contributor I
Guide to setting up RAP via USB LTE?
Hello all,
I'm working on getting a RAP up and running over a USB LTE adapter.  I've got what should be a supported configuration - 205H, Inseego U730L, and I'm running 8.4.  However, I haven't had luck finding the process of convincing the RAP to use the LTE adapter for the uplink.  Is there any good guide someone could point met at?
thanks!
