Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Trusted Contributor I
Re: HA fast failover configuration giude
DSP i would start a new thread if i were you, these are partly totally different questions.
1) not 100% sure,  but i believe if you provision them to a local controller then they can restart fine without the master being reachable. new APs might have issues to get into the system.
2) it might get them there, but the locals will be kinda unmanagable without a master so not sure if this will do any good. asssuming 1 is correct you don't need this anyway.
3) i believe i get auth request from my local controllers in clearpass, so that will keep working
3 again and 4) you lost me a little there. as mentioned start a new thread, add some info on your exact setup (image, device types, version) and repost.
Highlighted
When i read all the discussions, feeling better to go with VRRP only. In a normal campus environment, normally will not use master-local set up (Active/Active will work properly only with Master-local set up)
Please correct, if i am wrong.
Reg,
Shamz
Highlighted
It is simpler to setup VRRP-based or LMS-IP-based failover, sure.  HA failover is definitely faster and offers quicker recovery from a controller failure.  The good part is that we have a choice.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Thanks for your tech note;
In the Active/Active, the controllers will synch only if the setup is Master-Local. In case of Master-Master; required Airwave.
am i correct?
Reg,
Shamz
Highlighted
If you use master/backup master they will sync their configurations. Backup masters cannot terminate access points however.
If you have a master/master install Airwave is required to synchronize configurations, yes..
Highlighted
Moderator
Also, just to clarify, master/local is still technically active/active as both controllers can terminate APs.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Just one more thing for clarification;
in Master/Master setup with VRRP, Airwave required or not to synch the controllers?
Reg,
Shamz..
Highlighted
Only in master/local or master/backup-master are the configurations synchronized automatically.  All other scenarios they configurations must be synchronized manually or with airwave.
Highlighted
Moderator
Just want to confirm - master-master redundancy cannot be used with HA, because in HA mode the APs will establish tunnels to both controllers, and a master that is currently in standby mode will not terminate AP tunnels.  Is that correct?
The solution would be to remove master-master redundancy, make both controllers into standalone masters, and use AirWave to ensure that configuration is kept synchronized.  Correct?
Jon Green, ACMX, CISSP, CISM, and a bunch of other acronyms
Aruba Security CTO
Highlighted
MVP Expert
HA with Master redundancy :
It is supported starting AOS 6.4 and up
Thank you
Victor Fabian
Lead Mobility Architect @WEI
