Re: HA fast failover configuration giude
@jgreen wrote:
Just want to confirm - master-master redundancy cannot be used with HA, because in HA mode the APs will establish tunnels to both controllers, and a master that is currently in standby mode will not terminate AP tunnels.  Is that correct?
The solution would be to remove master-master redundancy, make both controllers into standalone masters, and use AirWave to ensure that configuration is kept synchronized.  Correct?
Supported, but....
Essentially, you end up pointing everything at the VRRP, so...
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
My issue has been solved. I just put all port channel in trusted.
Can controller master and standby is mix model? but It's same version
MVP Guru
Yes
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
