HPE 1920-8G-PoE+ (180W) Switch how to enable?
Switch HPE 1920-8G-PoE+ (180W)
I want to change the time value. ex) >en #conf t #(conf t) time 01/30/2019 19:00:00
But not enabled(en) and the cli command is limited. What are some ways to change?
<Switch>
initialize
ipsetup
password
ping
quit
reboot
summary
telnet
upgrade
<Switch>summary
Current boot app is: flash:/jg922a-cmw520-r1115.bin
Next main boot app is: flash:/jg922a-cmw520-r1115.bin
Next backup boot app is: flash:/jg922a-cmw520-r1115_bak.bin
HPE Comware Platform Software
Comware Software, Version 5.20.99, Release 1115
Copyright (c) 2010-2016 Hewlett Packard Enterprise Development LP
HPE 1920-8G-PoE+ (180W) Switch uptime is 8 weeks, 4 days, 1 hour, 23 minutes
128M bytes DRAM
32M bytes Flash Memory
Config Register points to Flash
Hardware Version is REV.A
Bootrom Version is 117
[SubSlot 0] 8GE+2SFP Hardware Version is REV.A
MVP Expert
Re: HPE 1920-8G-PoE+ (180W) Switch how to enable?
Try the following
_cmdline-mode on
All commands can be displayed and executed. Continue? [Y/N] Y
Please input password: 512900
system-view
Koen (ACMX #351 | ACDX #547 | ACCP)
