Contributor I
HPE Aruba Acclaim Badges
Acclaim has Aruba badges now and curious if anyone has added theirs? Cisco/CompTIA have accounts you login specificly to link to acclaim but I can't find anything HPE/Aruba related to do the same.
Just recertified my ACMP to 8 code and would like to add it for linkedin verification.
https://www.youracclaim.com/organizations/hewlett-packard-enterprise/badges
MVP Guru
Re: HPE Aruba Acclaim Badges
I've got a few on there. I think you just need to ensure your email address associated with HPE is registered on Your Acclaim.
Cheers
James
