Frequent Contributor II
Re: Hand Held RF devices lose network connectivity
min is 9 max is 15 and they are ALL at 9.  remind me where to find broadcast filtering?  i do believe that has been enable but I'd like to double check.  Also, I am not familiar with "Aruba utilities"
thanks,
rif
Is that for the 2.4ghz band (9)?  Broadcast Filtering should be on the Virtual AP profile...
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
yes 9 is the min for 2.4.  as far as Broadcast Filtering goes I do not see that exact function under the VAP rather is see:
Drop Broadcast and Unknown Multicast
Convert Broadcast ARP requests to unicast
could it be somewhere else?
rif
It is "Drop Broadcast and Unknown Multicast"
Yup already had that checked (enabled)
Also what was that about aruba utilities?
Rif
Aruba Utilities is an Android app that will tell you the signal strength of surrounding access points from the client perspective. It gives you and idea of coverage.
I will check that out. Any other thoughts?
Rif
Not right now, but I'm just guessing.  I would open a tac case in parallel.
In troubleshooting this RF device "dropping" problem I've been asked to run long term packet captures on a WAP.  In the past I've sent the capture data to my Mac running wireshark.  I cannot use my Mac as a long term destination for the capture data.  Is there a way to leverage the controller or Airwave for a long term packet capture?
rif
What make/model are these devices with the dropping issue?
