Help Cluster High Value Traffic not replicating
  • 1.  Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 01:01 PM
    Whitepapers and concepts are nice and all but I can't replicate the High-Value traffic session failover between Cluster nodes. If i reboot an A-UAC L2 cluster member the High-Value traffic drops...
    Shouldn't I see high value traffic on the second cluster member if I issued the "show datapath session high-value"
    Also I'm failing at creating a custom "high-value" traffic test policy for icmp.
    Ex:
    !sync-apps-s-uac
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan IPv4/6 Contract
    1 any any svc-icmp permit High 46 7 4
    2 any any app icmp permit High 46 7 4
    Hopefully these logs don't get too distorted...
    (PDC-VMC2) [MDC] #show lc-cluster group-membership
    Cluster Enabled, Profile Name = "PDC-Cluster"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 50%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 30
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    peer 10.60.11.2 128 L2-Connected CONNECTED (Member, last HBT_RSP 22ms ago, RTD = 1.587 ms)
    self 10.60.11.3 128 N/A CONNECTED (Leader)
    (PDC-VMC2) [MDC] #
    (PDC-VMC2) [MDC] #
    (PDC-VMC2) [MDC] #show user-table
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name User Type
    10.60.10.205 e8:4e:06:6d:a7:c7 allow-all-aar 00:00:42 G1-AP Wireless ACMX-Q/70:3a:0e:fa:26:e0/g-HT ACMX-Q tunnel Win 10 WIRELESS
    User Entries: 1/1
    Curr/**bleep** Alloc:2/146 Free:1/144 Dyn:3 AllocErr:0 FreeErr:0
    (PDC-VMC2) [MDC] #
    (PDC-VMC2) [MDC] #
    (PDC-VMC2) [MDC] #
    (PDC-VMC2) [MDC] #show datapath session high-value
    Q - Real-Time Quality analysis
    u - Upstream Real-Time Quality analysis
    E - Media Deep Inspect, G - media signal
    r - Route Nexthop, h - High Value
    A - Application Firewall Inspect
    B - Permanent, O - Openflow
    L - Log
    Sync-Flags: S - SYNC sent to Standby, A - ACKed by Standby
    D - Marked for delayed delete
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes SIDX Flags Sync-Flags User-MAC CPU ID
    10.60.10.205 90.130.70.73 6 54994 27370 0/0 0 0 0 tunnel 12 cf 94982 4109824 c6a Ch S E8:4E:06:6D:A7:C72
    (PDC-VMC2) [MDC] #exit
    (PDC-VMM1) [mynode] #show global-user-table list
    Global Users
    IP MAC Name Current switch Role Auth AP name Roaming Essid Bssid Phy Profile Type
    10.60.10.205 e8:4e:06:6d:a7:c7 10.60.11.3 allow-all-aar G1-AP Wireless ACMX-Q 70:3a:0e:fa:26:e0 g-HT ACMX-Q Win 10
    Total entries = 1
    (PDC-VMM1) [mynode] #logon 10.60.11.2
    (PDC-VMC1) [MDC] #show datapath session high-value
    L - Log
    (PDC-VMC1) [MDC] #
  • 2.  RE: Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 01:36 PM
    Is the cluster layer 2 for that vlan?
    "Show user-table standby" should show the users that the are replicated from another controller.
    "Show datapath session table" should have the flag "h" for high value sessions
  • 3.  RE: Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 01:45 PM
    L2 Connected cluster
    If I issued the show user-table standby on the S-UAC I see the user.
    show datapath session high-value on the S-UAC shows nothing.
    show datapath sessigh high-value on the A-UAC shows the "h" session.
    The gateway for the client is a core switch.
  • 4.  RE: Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 01:53 PM
    I would open a TAC case, to see if something specific is preventing it from working. Those should be the only requirements.
  • 5.  RE: Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 01:56 PM
    Okay no worries.
    As for creating a custom service like SSH to be a high-value..
    Creating a session rule to make the APP as TOS 46, High Priority would trigger that being a "High-Value" as well?
  • 6.  RE: Help Cluster High Value Traffic not replicating
    Posted Oct 12, 2019 02:10 PM
    UCC (voice/video calls that are identified) SSH sessions and TCP sessions longer than 10 seconds should automatically be considered high value sessions.
