Highlighted
MVP
Re: Help with Error: DHCP-OPTION82 relay agent receive, bogus giaddr
Also I noticed that this log appears in the show log errorlog - however in the configuration of the syslog events we can see, wireless, user, system, security, network, arm, ap logs to enable or disable however nothing for the errorlog - are events for this forwarded automatically ?
Highlighted
MVP
OK so a bigger issue than first thought it doesn't allow clients trying to connect to get an IP address from the DHCP helper.  Then in the logs I can see it generates that error message about DHCP82 even though this isn't ticked anywhere on the controller and it is giving the interface IP as a bogus address.  I think this is something to do with having these set up in a cluster.  In the meantime i have removed the cluster and everything is working as expected and the DHCP82 messages have now disappeared.  Any ideas what I have done wrong?
Highlighted
You should consider opening a TAC case.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
MVP
I have one raised just waiting on response.
Just thought i would share findings here in case anyone else experienced similar issues.  Hopefully get to the bottom of it soon
