Contributor II
How do APs react to high Temp environments
I have IAP 205 in  warehouse 35ft high. All was fine until a recent heat wave. Not disconnects and drops are experienced. No AC in the warehouse and temps are getting up to 90 degrees F on the floor. 35ft up could be higher. IAP 205 i belive can withstand temps of 104. What kind of behavior can be excpected from an AP that is  beyond its  enviromental heat recommedation?
MVP Expert
Re: How do APs react to high Temp environments
The AP-200 series recommended operating temperature is 32 degrees (F) - 104 degrees (F) as you mentioned.
For information about the internals of an AP - google "Anatomy of an AP aruba" and you can review the parts inside, but a lot of the AP is made of plastic, so theoretically higher temps could cause components to become damaged.
I think the recommended AP for an environment that exceeds temperature or other conditions would be the AP-228 (up to 140 degrees F) for 802.11ac Wave 1. If that AP continues to have trouble, it may be worth considering swapping for that model.
I would consult your local Aruba rep for more details.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
