Contributor II
How to add a device role id to a role for device account role with MPSK
Hello I have created the MPSK wizard with 1 device role named Med_App. Now i want to add a second one but where can i add it or bind it?
So i added GBS role with id 3006 but cant use it when i want to add a device.
Aruba ACCX #749, ACDX #793, ACMP, ACEAP | HPE Master AS
contact: thierry.lubbers@axez.nl
MVP Guru
Re: How to add a device role id to a role for device account role with MPSK
Have you already tried to just re-run the MPSK wizard and add the new roles in there? That should be the easiest way and allows re-running the wizard later again.
Contributor II
Hello Herman,
I have done this. And yes than it is configured and added.
So this works.
But the service is put back at the bottom and need to be put back at the right place.
Also some extra config done by hand was deleted.
If the wizard can do it, it should also be done manually.
