Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Occasional Contributor I
How to connect the iPhone 11 Pro Max with Wifi 6 to the AP535s?
I got now a couple of AP535 (8.5.0.3_72498 FW) in the network (beside IAP325) and wanted to see how the new iPhone 11 Pro is connecting to the new APs. The client report in Aruba Central shows 802.11g or 802.11a connectivity with slow client max speeds for the iPhone 11 Pro Max, whilst the iPhone Xs Max seem to be going to the max with 802.11ac. (same location 2-3 meters from the AP535s). Please advise how I can ensure that the iPhone 11 Pro's connect with Wifi 6/ax?
iPhone 10S Max on a random AP535 in the network:
CONNECTION
CHANNEL
100 (80 MHz)
BAND
5GHz
CLIENT CAPABILITIES
802.11ac,802.11v
CLIENT MAX SPEED
1.30 Gbps
iPhone 11 Pro Max on a random AP535 in the network:
CHANNEL
100 (80 MHz)
BAND
5GHz
CLIENT CAPABILITIES
802.11a,802.11k,802.11v
CLIENT MAX SPEED
54 Mbps
iPhone 11 Pro Max on a random AP325 in the network:
CONNECTION
CHANNEL
116 (80 MHz)
BAND
5GHz
CLIENT CAPABILITIES
802.11ac,802.11k,802.11v
CLIENT MAX SPEED
1.30 Gbps
Highlighted
Contributor I
Re: How to connect the iPhone 11 Pro Max with Wifi 6 to the AP535s?
Share the SSID config?
I've had one customer report anecdotal connection issues where iPhone 11 Pro cannot connect to AP-510 series running 8.5. Haven't been able to duplicate.
