We are on the process of migrating to AOS8 and I can't seem to find if there is a box I need to tick to enable IPv6 for clients. On our AOS6 production, IPv6 works just fine for clients. I am using the same VLANs and those are IPv6 ready so I don't think I have problems on the router side. It's just that the AOS8 Controllers doesn't seem to give out IPv6 or maybe simply not enabled.
I've been searching on how to enable it on AOS8 but no luck so I ended up here asking for help. Thanks.
