Highlighted
How to fasten AP booting process
Dear Guys
I have a controller Alcatel Lucent 4030. IAPs that i have converted to APs are (103,105 & 115). The issue that i am facing is as soon as the AP boots up is takes approxametly 10-13 minutes, please guide me how to reduce this time so that the AP boot up fastley.
AP takes ip address from external DHCP. All APs and external DHCP is on same VLAN.
Highlighted
Re: How to fasten AP booting process
What version of AlcatelOS is this?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Contributor II
RE: How to fasten AP booting process
If you want to solve the answer, you need more network configuration and configuration information. We can not suggest a way to reduce boot time by simply using DHCP information. If the image is downloaded in advance, you can save time on the next boot. In 1/3
Highlighted
I am using OS6.5
Highlighted
MVP Guru
All AP's will take a set amount of time to boot unless there is an external factor (such as a response delay in DHCP/DNS for example) which can affect this. Have you reviewed the console output of an AP booting and confirmed if there is anything out of the ordinary there?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
