Highlighted
Regular Contributor II
How to hide a WLAN (SSID)
I am very new to Aruba Wireless and I am setting up a Wirless Test Lab.  I have the devices setup and AP Groups and Managed Device Group created for basic functioanlity; but, the next step is to setup the WLANs
For our test environment we need to replicate what our current HP MSM760 setup and some of this SSIDs (in produciton) are hidden.
My question is how may I hide the new test SSID?
Will I need to create it first (broadcast on) it to the MD groups (pg. 30) and then hide it afterwards?  HO may I hide th etest SSIDs?
Accepted Solutions
Highlighted
Re: How to hide a WLAN (SSID)
This link may be of assitance: https://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Unable-to-hide-ssid/m-p/11741
I just wanted to verify if anything changed in verison 8.3.0.3?
So is that correct?  I wil nee dto creat ethe SSID and then check the "Deny Broadcast Probes" option in the advanced settings in addition to the "Hide SSID" option?
View solution in original post
Highlighted
Nothing has changed.
You will still need to do what you indicated above in the SSID profile.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
MVP Expert
Make sure you go to the right hand side and then click on your login > Preferences > Click show advanced profiles
Then go to System > Profiles > Wireless LAN > SSID > and enable
* - Hide SSID:
* - Deny_Broadcast Probes:
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
All Replies
Highlighted
Highlighted
Highlighted
MVP Expert
* - Hide SSID:
Thank you
Victor Fabian
