Highlighted
MVP Expert
IAP 215 and 315 don't join same cluster
Hi guys,
I know all the points that can prevent IAPs joining the same cluster, but right now I have this issue: just two IAPs, IAP-215 and IAP-315 are in the same subnet but they join in the same cluster, each one is its own VC. Points I have already checked:
  1. Two IAPs are in the same version which is 8.5.0.5.
  2. Two IAPs are in the same subnet, and they can ping each other.
  3. There is no firewall blocking ports between them.
  4. Auto-join mode is enabled.
  5. Preferred master is disabled.
Last thing I did is to factory reset IAP-215, but it reboots broadcasting the SetMeUp... SSID and it didn't join to IAP-315. What can I do? What command shall I use to troubleshoot this? Do you need any output?
Julián
Highlighted
MVP Expert
Re: IAP 215 and 315 don't join same cluster
I attach the "show log system" for both IAPs. Any idea?
Julián
Highlighted
Can you post the output for the following command from both the IAPs?
show election statistics
